It is currently Tue Aug 19, 2025 4:56 am
PostPosted: Mon Apr 12, 2010 12:25 pm
Are there any tricks to apply a little glue as needed to the edge of a spruce top that I will be joining ? Last time the excess glue left some little spots.
PostPosted: Mon Apr 12, 2010 12:49 pm
The way I read this, the implication is that your excess glue left spots on the wood last time you joined a top. I think the solution is to join your plates before you reduce the thickness to final dimensions.
Whether you remove excess glue immediately or after it sets up a bit is not critical, if, after you have joined the plates, then you finish plane or sand to final thickness. The act of finish thicknessing by sanding and/or planing will remove any excess glue.
